Mini me swap please read
Just swapped a z6 head on my y7. Car started up fine idled ok then started to bogg down and you would have to hit the throttle to save it from dieing. Well after running for about 10 min. it finally just completely died and wont start at all, checked for spark, getting no spark at the plug. Im getting a weird ticking sound when trying to start it (using chipped p06 btw). I hooked the P2E back up to see if it would make a difference.. still nothing. It will crank just not turn over. I checked grounds im using the y7 distributor if that makes a difference, and i changed the coil in the dizzy. Any help would be appreciated thanks guys.
shauniewalnuts
Jun 27, 2005 08:20 PM
