Clutch Getting Weaker, Almost Non-existant
Old May 15, 2009 | 06:43 AM
96 EX's Avatar
Default Clutch Getting Weaker, Almost Non-existant
My clutch in the last 3 days has continually gotten worse and worse. The clutch is almost non-existant at this point as well as hard to get into gear. I read on a couple post to check the Master & Slave cylinders as well as the adjusting screw underneath the clutch pedal. I looked underneath my clutch and noticed the assembly is a little lose but there is a big glob of grease at the firewall as well. Any idea's?
Old May 15, 2009 | 07:04 AM
'95hatchCivic's Avatar
Default Re: Clutch Getting Weaker, Almost Non-existant
change master go from there its either that or slave or pressure plate took a **** is it hard to put it in gear like you have to jam it and does it grind in reverse?
Old May 15, 2009 | 07:32 AM
96 EX's Avatar
It doesnt really grind going into reverse just if I'm driving and I try to downshift its hard to get into gear. The pressure plate and clutch should be good, I dont run the **** out of this engine like I could plus its a Centerforce Stg2 clutch ect. But like I said the pedal is useless for about 6/8's of the pedal. And it seems to be getting continually worse. And whats up with the grease by the clutch pedal and firewall? Cant exactly investigate as I'm at work.
Old May 15, 2009 | 07:54 AM
Got Warts's Avatar
Same thing happened to me...a spring broke on the disc and would jam up and get in the way, not allowing the clutch to fully disengage allowing me to get it in gear.
It sucked.
When you say the clutch is almost nonexistent, are you saying there is no pedal feel or resistance? If so, then it has to be air in the line, a leak, or one/both of the cylinders is shot.
Edit: read your second post. Sounds like the second part I wrote.
Old May 15, 2009 | 07:58 AM
96 EX's Avatar
It sucked.
There is basically no pedal at all, it will engage and disengage fine but it only uses 2/8's of the pedal which is a pain in the ***. At the junkyard there were two EJ8's like mine with the master cylinders in them, think I should just pick up a master + slave cylinder and go from there? Or should I go buy a rebuild kit for the master ?
Old May 15, 2009 | 08:47 AM
thi3v3z's Avatar
when you beat on it, does it rev up but not go anywhere???
Old May 15, 2009 | 08:49 AM
speedooo's Avatar
If you aren't losing fluid then it's not the master or slave cylinders
Old May 15, 2009 | 09:34 AM
96 EX's Avatar
Checked the fluid and it was bone dry. Getting ready to add more to see if the pedal gets firmer. Going to re-bleed the system as well. I havent noticed any leaks in my engine bay, but I do keep it clean so that could be a factor lol. At this point I'm looking at the master or the slave cylinder. Input is welcome.
Old May 15, 2009 | 09:40 AM
1992Si's Avatar
As you have learned, don't clean everything so often. If your going to, make sure you pay attention to the small details such as leaks.
Both parts are fairly cheap so it won't hurt to bad...
Old May 15, 2009 | 09:41 AM
hannslebo's Avatar
i had the same problem i had to keep refilling my fluid..it was leaking from my slave cyl...soo i replaced the slave cyl bleed the system and refill and it was like new
Old May 15, 2009 | 10:02 AM
speedooo's Avatar
add fluid and pump the pedal...it will come back on its own as you pump it. check for fluid under the carpet inside the car, check for a leak around the slave, if not those then you have a line issue
Old May 15, 2009 | 10:29 AM
96 EX's Avatar
Added fluid and everything is a go, I'll keep a watch on leaks around the master/slave. Thanks for the replies so far.
Chris Miller
Mar 28, 2016 10:49 AM
Edul59
May 19, 2009 07:37 PM
ch0baca
Mar 11, 2009 02:11 PM
vtec69
20
May 4, 2005 05:48 PM
esca
Oct 1, 2004 10:27 AM
