ok hood pin holes
Old May 15, 2009 | 05:28 AM
shoklid's Avatar
Default ok hood pin holes
so i fed up with the previous owner drilling holes in the hood. anyone fix this prob before? weld the hole or tiger hair it or bondo? anyone who has done this help me lol
Old May 15, 2009 | 05:50 AM
fasteddy089's Avatar
Default Re: ok hood pin holes
honestly, i doubt its worth the hassle. i'm sure welding is the best bet to avoid bondo problems down the road, but if its a stock hood why don't you keep an eye out for one in the marketplace, junk yards, etc. you could get it cheap for sure
Old May 15, 2009 | 05:56 AM
shoklid's Avatar
yea the local salvage yards want like 100 to 150 bucks. and i already got tiger hair and bondo left over from fixing the usual honda quarters that rust out. so id like to use the left over supplies up
Old May 15, 2009 | 06:03 AM
you may be able to get away with bondo, but with the flex that goes on in the hood when closing, i'd be worried you'd have problems down the road. i'm sure someone on here has tried it before though
Old May 15, 2009 | 06:08 AM
shoklid's Avatar
i know im worried about closing the hood and the damn bondo falls out that would be awsome ....NOT haha that would suck
Old May 18, 2009 | 06:42 AM
shoklid's Avatar
bump. does anyone have any clue for an easy fix. i know there are many ppl on here that have this prob as well from prev owner dumb ****
Old May 18, 2009 | 08:29 AM
jamelin's Avatar
the best thing would be to cut a square hole around the drilled hole then weld in new peices, grind the welds and use bondo to cover that. if you do it right there is only need for a very small amount of body filler.
Old May 18, 2009 | 08:34 AM
EG6KILIN's Avatar
jb weld then use a little of icying an primer an paint
Old May 18, 2009 | 12:36 PM
shoklid's Avatar
ok thanks guys ill let u know what i do and update how it holds
Old May 18, 2009 | 12:42 PM
jamelin's Avatar
dont use jb weld, thats not gonna work very well. just do it right the first time so you dont have to do it multiple times. weld in peices
Old May 19, 2009 | 12:51 PM
agreed
Old Jul 2, 2009 | 07:10 PM
xfrankx's Avatar
i would weld up some small squares under the hood and just weld the holes up. grind it down and use minimal filler. more work than buying a hood from a salvage yard
Black Diamond
Paint and Body
12
May 16, 2009 06:17 AM
null.
Sep 7, 2004 09:34 PM
csm84
Jul 17, 2003 08:57 AM
Denny
May 13, 2003 05:09 PM
phazeshifter
Jan 15, 2003 02:56 AM
