Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
please help if you have seen or had this problem!!
Old May 14, 2009 | 10:23 PM
bmwst9's Avatar
Default please help if you have seen or had this problem!!
ok so i posted on here a while ago about how my car looses power when vtec switches over..no one believed me so i went to the dyno..and from the last time i was there i lost 57 whp. i dont know what the hell it could be..here are some of the things ive tried
new plugs
new intake
pulled the solinoid screens to see if they were clogged
changed oil
pulled off exhaust figuring maybe it was clogged
pulled off valve cover to look at cams and they were all fine
if you have any other ideas please let me know!! i really cant figure this thing out
by the way ..my mods are reflash, i/h/e, TBS, heatshield
Old May 14, 2009 | 10:31 PM
JDM FERIO RS's Avatar
Default Re: please help if you have seen or had this problem!!
ouch a dip by 57 damn something def not right, but it seems like something isnt ready correctly since u had the reflash, but cant pinpoint
Old May 15, 2009 | 04:44 AM
clemsonhatch's Avatar
Please post dyno so we can see what is going on. If at all possible post before and after.
Did it lose power just in VTEC or across the whole range?
Have you checked your compression? Is VTEC engaging? Does it sound different?
Old May 15, 2009 | 05:17 AM
madmatt's Avatar
+1 on compression check
Any check engine lights?
Old May 15, 2009 | 07:31 AM
bmwst9's Avatar
truthfully i didnt even ask them to print them out cause it was so embarrassing.but on the low cam the pull looked normal..we even pulled up another si dyno with the same mods and both of the pulls looked exactly the same on the low cam..but as soon as 4800rpms came and was supposed to switch to vtec it fell flat on its face and basically flat lined on the dyno chart.
it did sound like vtec was engaging but the motor gets abnormally loud..like 3 times as loud as normal.
we did check the compression and everything was ok
Old May 15, 2009 | 07:32 AM
bmwst9's Avatar
and no..i havent had 1 check engine light..which sucks because i wish i would just so i have a general idea of where the problem is at
Old May 15, 2009 | 07:33 AM
Focal204's Avatar
Never heard of that before. Really strange that the car is getting louder than normal.
Old May 15, 2009 | 01:11 PM
ChargedSI's Avatar
I would post this issue on the Hondata Forum, under K20 reflash. Sounds like something might be goofy with the reflash. Hopefully you did buy the reflash through an authorized dealer.
Good Luck
Bradlo
Dec 10, 2017 03:58 PM
wist00s2k
Mar 15, 2015 06:22 AM
SoLo26
Honda S2000
11
Sep 19, 2012 07:38 AM
vtecyboy
Aug 11, 2008 02:16 PM
ensracer
Mar 30, 2004 08:51 PM
