quick question...
Old May 14, 2009 | 09:15 PM
got00rice's Avatar
Default quick question...
ok i have a 96 civic hb and it has a ls integra swap obd2. right now its wont start too good. but my question is can i used a obd2 ls integra engine harness to replace the harness in it right now. i believe the harness is the stock 96 harness. reason why i pick the ls harness up is because im gonna pick it up for a cheap price and i think something is wrong with the harness that i have right now so let me know thanks.
Old May 14, 2009 | 09:29 PM
Unseen Racer's Avatar
Default Re: quick question...
so you have an OBDII LS in your hatch and you want to know if an OBDII LS harness will work??????
uhhh yes.
its identical.
got00rice's Avatar
ok thanks just want to know before i pick it up tomorrow.
Old May 14, 2009 | 09:30 PM
yes you can use it.
using another OBD2 LS harness to replace your OBD2 LS harness is good.
Old May 14, 2009 | 09:41 PM
R666_EK's Avatar
Umm. NO. The harness in it is probably the stock civic harness. Its a one piece harness. The LS is a 2 piece that separates at the pass. shock tower. It won't work. Its just an LS use another civic harness.
Old May 14, 2009 | 09:56 PM
it will work!
he has an OBD2 LS harness and he wants to replace it with ANOTHER OBD2 LS HARNESS!
it will work!!!!
its freaking plug and play!
Old May 14, 2009 | 11:26 PM
R666_EK's Avatar
Ok read his post again. How many people would go through that when the factory civic harness is pretty much plug n play?
Old May 14, 2009 | 11:32 PM
waaBAAH's Avatar
you will need both two pieces from the LS harness. most people forget the 2nd piece.
whats wrong with the car that makes you think you need a harness?
Old May 15, 2009 | 05:53 AM
got00rice's Avatar
the motor swap was crappy but its ok. they slice wire and just twist the wires together without soldering or anything so i just wanna reclean everything out and make it into a clean swap. plus the car bogg bad at a certain rpm but if u push it pass that it'll be fine. kinda like its running on a limp mode. but thanks for the help guys
hYbRid_Eg6
Apr 16, 2009 09:44 PM
lilv
Oct 6, 2008 12:05 PM
Superdragr45
Apr 27, 2005 09:28 PM
topspeed86
Oct 30, 2004 01:47 PM
