Air Compressor Clutch relay???
Old May 14, 2009 | 07:23 PM
8_UR_AWD's Avatar
Default Air Compressor Clutch relay???
Well I have a 99 honda civic SI and I cannot figure out were the AC clutch relay is at??? I checked everything else and I have narrowed it down to it being a relay... the low pressure switch works... all the fuses are good... under hood and dash... Has plenty of freon and I jumped power to the compressor and it worked... so Im imagening there has to be a relay somewere... anybody know?
anybody have same the same problem?
Need help asap...
Its hotta than a **** in cali! lol
Old May 14, 2009 | 07:29 PM
Former User's Avatar
Default Re: Air Compressor Clutch relay???
Old May 14, 2009 | 08:16 PM
8_UR_AWD's Avatar
Hey thanks alot bro! So now that i know were its at I checked it but he relay is good...
I jumped it with a wire and the clutch activates! yay!
now for the activation wire on the relay
on side show constant hot but the other pin dosent show anything.... Could it be that the ac controls are mesed up? or the fuse box?
cause it kicks the condensor fan on but it wont ativate the clutch realay???
anybody know?
Old May 14, 2009 | 08:31 PM
Check the A/C pressure switch.
Next check wires between the condenser fan relay and ECU A27 and the Blk/Red wire that runs between the relay and ECU A17. Otherwise, the ECU may be bad.
Old May 14, 2009 | 09:35 PM
8_UR_AWD's Avatar
Dam!!! the ecu has to do with the AC? wtf? lol thanks for you help ill keep this updated...
Old May 15, 2009 | 10:05 PM
8_UR_AWD's Avatar
Hey bro! Thanks alot for the Help! I swapped out my ecu and wam!!! It works! Thanks alot...
whahappened
Acura TSX
Nov 2, 2012 03:20 PM
vanser3004
Honda Civic (2001 - 2005)
May 31, 2010 04:46 PM
hondaZvic
Sep 22, 2009 06:04 PM
ksamsel
Acura TL, RL & ZDX
Dec 8, 2008 02:55 PM
turbob16ef
Jan 11, 2006 03:47 PM
