HELP! Problem with lighting
Old May 14, 2009 | 05:44 PM
TheCivicMafia's Avatar
Default HELP! Problem with lighting
Yesterday my car got rained on, Window was down for 2-3 minutes..
Now my dash lights dont work ( cluster and ac area ) Nor do my Tail lights or corner lights up front
I have brake light and head lights i checked all fuses, all are fine, Anyone know the problem? Any help is appriciated
Old May 14, 2009 | 05:57 PM
thi3v3z's Avatar
Default Re: HELP! Problem with lighting
Did you check fuses by eye, or with an actual tester?
Old May 14, 2009 | 06:33 PM
Checked them with a fuse tester with power on and with a meter to be 100% sure all fuses were working properly i was wondering if it may have been a dimmer switch or idk
Old May 14, 2009 | 07:06 PM
Former User's Avatar
What year Civic?
Old May 14, 2009 | 07:18 PM
94 civic dx hatchback
Old May 14, 2009 | 07:24 PM
All lights currently not working are on a single circuit protected by fuse #19 under the dash. Double check whether fuse #19 is blown.
Old May 14, 2009 | 07:26 PM
Yeah i checked that one according to my book as it matches all of the discription, i even replaced that fuse, still doesnt work
Old May 14, 2009 | 07:40 PM
Pry the dimmer switch out of the dash, unplug the connector, turn the parking lights ON, and check whether you measure 12V at the pin for the Red/Black wire in the wire harness connector to body ground. If not, check whether you measure 12V to body ground at the battery side terminal of fuse 19 when the parking lights are ON.
Old May 14, 2009 | 07:55 PM
I just checked dimmer switch. no power, i even grounded to the body I pulled fuse #13 no power even to fuse box
so any idea?
Old May 14, 2009 | 07:58 PM
Did you mean fuse 19? Was the combination switch in the parking lights position?
Old May 14, 2009 | 08:00 PM
Yeah, its the one that says " instrument lights, tail lights, parking lights"
yeah i turned it on both, first one and then second one, because there on when highlights are on
Old May 14, 2009 | 08:09 PM
Do the headlights work? If so, check the combination switch in the parking lights position:
Old May 14, 2009 | 08:24 PM
civic_driver's Avatar
Fuse are not tested under power. You have to take it out and test it using the continuity function on a multimeter or the resistance meter.
Old May 14, 2009 | 09:52 PM
civicmulisha's Avatar
no he is saying he tested where the fuse plug into and no power where it plugs into i belive
Old May 15, 2009 | 03:52 AM
Laz's EP's Avatar
check your switch,its probably wet
Gatschet
23
Aug 25, 2021 10:35 AM
defensa24
Mar 8, 2011 06:45 AM
95silverteg
Sep 30, 2008 04:48 AM
Marcos
Mar 23, 2004 11:21 AM
