lsvtec question plz help
Old May 14, 2009 | 05:28 PM
bayron's Avatar
Default lsvtec question plz help
ok i have lsvtec into my ef.. but im using it with pr3.. which ecu is good 2 use wih the lsvtec... and i have p30 but the thing is obd1.. i have the jumpers for the ecu.. but can some1 converte my distri to obd1..ill pay thats all i need change the harness for the distri to obd1 thanks
Old May 14, 2009 | 05:29 PM
bayron's Avatar
Default Re: lsvtec question plz help
so which ecu should i use for the lsvtec?? help plz
Old May 14, 2009 | 05:35 PM
crx_si-r's Avatar
no go with converting the obd0 distributor to obd1. the obd1 and obd0 distributors use different pulse readings (the gear on the shaft inside the dizzy). you would need to buy an obd1 distributor and 4 wire o2 sensor in order to get everything working right. seeing as you already have the ecu and ecu jumper harness. pm me if you want an obd0 to obd1 dizzy jumper harness. you could also get your obd0 PR3 ecu chipped to your specifications. i have a chipped obd0 pr3 ecu that i was running until i converted to obd1
Old May 14, 2009 | 05:39 PM
sh!ft's Avatar
Who the fack changed my title?!
wrd.....
http://www.phearable.net/shoppingcar...per-pi-75.html
Pancho2193
Mar 2, 2013 06:35 AM
88EDHatch
Nov 12, 2010 11:27 AM
prelude2121
Engine Management and Tuning
Oct 29, 2010 04:23 PM
whitecivic11
Mar 28, 2010 11:04 AM
G2integra217
May 8, 2005 11:39 PM
