ls vtec help (dowel pin question)
so i started to get my motor together and when i was putting the dowel pins in i noticed that 1 dowel pin was bigger then the other. the bigger 1 fits snuggly in the block but wnt go over the head gasket.The smaller 1 fits in the block loosely and the head gasket DOES fit over it.
its a golden eagle kit that i bought a long time ago.Can i bore out the head gasket hole or do i need new dowel pins? the head gasket is OEM
are you putting them on correctly?
bigger side to the head, smaller side to the block.
If you need to you can bore open a little the gasket.
Have you contacted GE?
You need LS/VTEC dowel pins. KMS used to sell them. You can get them on EBAY
Last edited by 92civlude; May 15, 2009 at 01:36 PM. Reason: Sorry. You get it. I didnt read your question all the way
yea i put them in right and they are LS vtec pins....i got them to work took the head gasket to the drill press and took the hole out a lil bit to get it to work
1990hf
May 20, 2008 06:56 PM
