no codes????
Old Aug 18, 2002 | 08:12 AM
vrrodri's Avatar
Default no codes????
I get no codes, not even the "engine normal" codes when I jumper the 2p connector.
The engine light does not flash. anyone knows why this is?
Old Aug 18, 2002 | 08:15 AM
bullz's Avatar
Default Re: no codes???? (vrrodri)
explain your situation better please....(????)
Old Aug 18, 2002 | 08:22 AM
Archidictus's Avatar
Unceasing Measure
odds are, you're bridging the wrong circuit(s)
edit: we need more information to help you, son
[Modified by Archidictus, 12:22 PM 8/18/2002]
Old Aug 18, 2002 | 08:29 AM
vrrodri's Avatar
Default Re: no codes???? (iLLestjr)
I jumped the 2 p connector to check for codes (engine trouble codes). I have always seen a "no problem code" in other cars such as a code 12. I figured I would at least see that in my civic, but nothing happened.
This is the same 2p connector used to also adjust ignition timing.
Any ideas?
Thanks
jeux
Jul 10, 2004 08:40 PM
integraL
Mar 19, 2003 09:30 PM
vrrodri
Nov 27, 2002 11:45 AM
Todd00
May 24, 2002 07:04 PM
