14b Turbo Maintenance// Info
Old May 13, 2009 | 10:16 AM
ware's Avatar
Default 14b Turbo Maintenance// Info
  • I purchased a 14b turbo about a year ago and finally going to put it to use. However before i do i want to make sure its in good condition. What are some simple ways to check for anything that will cause issues? (shaft play, leaks, etc)
  • For this type of turbo am I required to run coolant lines? I've seen a few with but is it a must?
Thanks fellas
Old May 13, 2009 | 10:32 AM
EJ8 944's Avatar
Default Re: 14b Turbo Maintenance// Info
Check for shaft play by grabbing the center of the impeller shaft, and moving it side to side, and in and out. Some movement is acceptable, I think generally no more then 1-2mm of movement is best for side to side movement. Any in and out movement might indicate a problem.
Old May 13, 2009 | 10:54 AM
redlinetuning's Avatar
for turbines that use both coolant and oil, it is best to run both for longevity. They are there for a reason.
run some oil through the chra to lube the assembly, and like the previous post said, check the shaft for any play.
Old May 13, 2009 | 12:52 PM
EJ8 944's Avatar
An important point there, make sure there is oil in the center section, its not recommended to spin the impeller without lubrication.
MotoCARR
Sep 20, 2006 04:28 PM
turbotime
Mar 30, 2006 02:07 PM
Offer
Feb 28, 2006 11:27 AM
SleeprCrx
Sep 4, 2003 10:56 PM
mamaboy
Nov 24, 2002 08:17 PM
