BLOWN TURBO...
Old Sep 4, 2003 | 04:43 PM
SleeprCrx's Avatar
Default BLOWN TURBO...
Well, my buddy has a gen 2 teg... he recently installed a junkyard turbo kit using the audi 5000 k26 turbo... we've been through two different turbos, both of them started out with no shaft play and no wobble, but for some odd reason they have both messed up... it seems as though the turbo shaft is hitting the housing... we're stuck, and confused why this would happen to both turbos... anyhow, any help would do, also, paul_vang if you happen to read this... your help would be appreciated...
Old Sep 4, 2003 | 04:47 PM
Canuk_SiR's Avatar
Default Re: BLOWN TURBO... (SleeprCrx)
is there alot more shaft play then there was when you first got the turbo?
Old Sep 4, 2003 | 04:51 PM
Tinker219's Avatar
Default Re: BLOWN TURBO... (Canuk_SiR)
Double check to make sure your oil return line is sufficiently sized, and high enough on the oil pan...
Old Sep 4, 2003 | 10:56 PM
SleeprCrx's Avatar
there's alot more shaft play... the shaft hits the housing... the oil return line is fine... but i dunno... we're thinking about trying a different turbo...
turbotime
Mar 30, 2006 02:07 PM
1FastCoupe
Jan 27, 2006 07:07 PM
teddy_dc2
Nov 5, 2005 04:54 PM
PHILLIPDEEZ
May 18, 2005 03:49 AM
OKSolSi
May 18, 2002 08:10 PM
