B18b1 into a Da
Old May 13, 2009 | 05:58 AM
BrunoNu2U's Avatar
New User
Default B18b1 into a Da
I have a 1990 integra and i have a b18b1 from a 97 ls and i was wonderin what i would need to make this swap work. i know that the cams are slightly more aggresive than the b18a1's cams and i was wondering if this would cause a problem. If it does cause a problem what would i need to correct it to make it work. If somebody could help me out on this that would be great.
Old May 13, 2009 | 08:59 AM
GsDAteg's Avatar
Default Re: B18b1 into a Da
I have a 97' B18B in my 90' DA. You don't need anything special to make it work, just drop it in. I stayed non-obd so I basically just used the block/head, everything else was from my old motor (IM, ECU, alt/dizzy, etc.).
Super easy swap, drops in like stock. Only thing you have to wire is a extension on the ECT switch (located on the thermostat housing instead of the block).
Don't expect much of a gain from the swap though because the header, intake manifold, and ECU have just as much to do with the 10-15hp gain as the cams do.
Old May 13, 2009 | 10:05 AM
jhammond_82's Avatar
Reject Papi
i would personally convert to obd1. all you'd need is an ecu, and jumper harness'. its a direct drop in, so you shouldn't have any issues doing it.
Old May 13, 2009 | 12:14 PM
BrunoNu2U's Avatar
New User
yea but goin that ways gona cost more money which i dont got its just gona be a rebuilt stock swap and the car is beat to hell so why waste the money, but thank you guys for the help i appriciate it
GoldLudeRay
Apr 13, 2012 03:06 PM
protopro88
Apr 6, 2011 10:01 AM
ek_antwizz_99
Jan 22, 2009 08:29 PM
. L i z
Mar 13, 2006 08:55 AM
pkgwjai082
Feb 1, 2006 07:48 PM
