T56 shifter for a Joe Gibbs supercharged Silverado
Old May 13, 2009 | 04:54 AM
Brad Campbell's Avatar
Default T56 shifter for a Joe Gibbs supercharged Silverado
I had a customer come in with a Joe Gibbs Racing supercharged Silverado. He had a 6 speed installed however the company that completed the swap botched up the shifter pretty bad. He wanted a custom length shifter that would allow him to leave his cup holders and fit the center console properly. Here is the base piece. I am going to make the final upper shifter rod out of 7 series aluminum. The base shown here is laser cut 304 stainless.
Old May 13, 2009 | 06:27 AM
shortyz21's Avatar
Default Re: T56 shifter for a Joe Gibbs supercharged Silverado
boring
Old May 13, 2009 | 07:24 AM
kommon_sense's Avatar
Could you cut a groove/slot into the base to allow the extension to slip in and be secured by bolts? It seems like the way the 2 pieces are shown in the picture that they will eventually loosen up over time.
Old May 13, 2009 | 07:28 AM
That could be done, but this is how it's done from the factory. 2 M8 fasteners and loctite should provide sufficient clamping force to keep this together for years of abuse.
Here is another aftermarket shifter for an example...
Old May 13, 2009 | 07:57 AM
-RedneckDave-'s Avatar
Working
Do you have any shots of the rest of the truck, or some shots of this installed?
Old May 13, 2009 | 07:59 AM
I'll get some of both. I just finished the part...
Old May 13, 2009 | 09:31 AM
DESTROYER's Avatar
Haha I was thinking the same thing... Joe Gibbs Silverado and all I get to look at is a stick
Old May 13, 2009 | 07:50 PM
Working
Exactly. I would love to see how this is in the truck, because I think it is a nice looking part simple or not.
Old May 14, 2009 | 02:59 AM
Ok guys here you go. I need to make some quick spacers for it, thread the rod for the shifter ball, and touch up the polish job, but it seems to work perfect.
Here are some pictures of the truck...
Old May 14, 2009 | 02:35 PM
JRSC01GS-R's Avatar
those trucks are badass, nice work on the shifter it looks good
Old May 14, 2009 | 03:06 PM
JDM KID 510's Avatar
Nice.
Old May 16, 2009 | 10:04 AM
HiProfile's Avatar
Damn what a sleeper! Must confuse people left and right.
I'm just confused why you'd need 7xxx alum. The only reason alum shifters break are because they are CAST metal, in addition to being low-strength CDM aluminum. I can understand wanting the extra strength, but I'd rather snap a shifter than a fork.
Old May 18, 2009 | 02:50 AM
It was just for the bling factor, no strength related reasons.
Old May 19, 2009 | 09:54 AM
Snafubmx234's Avatar
Fix the current fastener situation and you have yourself a decent little kit.
Old May 19, 2009 | 10:01 AM
If you are commenting on the length, the screws have changed for the finish install. I had to add spacers to get it to fit up properly. I'll post final pictures tomorrow. Finish installation tonight.
Old May 19, 2009 | 03:40 PM
JDMCRX's Avatar
Doesn't the silverado come standard ? Or is the standard version with no center console ?
Old May 20, 2009 | 03:13 AM
It may, i'm not sure. The owner told me that this model only came with a slush-box and he had it converted.
Here is the finished product. I timed the threads so the ball wouldn't need a jam nut. Nice clean installation...
Old May 20, 2009 | 03:26 PM
JDMCRX's Avatar
very nice work. More pics of it in the truck
rash
54
Oct 7, 2012 08:53 AM
fleabag
Honda Civic (2001 - 2005)
Aug 17, 2012 05:24 PM
07FG2
Honda Civic (2006 - 2015)
17
Jan 27, 2010 05:11 PM
i drive a honda
Mar 2, 2009 08:13 PM
turboteener
Welding / Fabrication
21
Aug 7, 2006 07:35 AM
