power window question
Old May 12, 2009 | 06:39 PM
gahyoursilly's Avatar
New User
Default power window question
Ok I have 2 windows that will go down...the drivers side and the back passengers side. I can't put the back window down from the front I have to use the button on the back door.
When I first got the car you could also move the front passengers side but only from that door again and then it started to only work when you had the door open and then not at all.
So I took the car to a shop a while back and they said it needs a new master switch or at least I think that's what it was called. But then he said the windows will only be able to be moved from the drivers side and not by the buttons on each door.
Is this right? Because for some reason it just seems wrong to me...
haydenm315
Jun 22, 2011 05:46 AM
chris4x4
13
May 8, 2011 10:39 AM
logic factory
Jan 27, 2011 03:15 PM
street_devils
Jul 21, 2008 05:31 PM
accord_2dr
Jun 22, 2007 01:55 PM
