Suspension & Brakes Theory, alignment, spring rates....
general suspension questions
Old May 12, 2009 | 04:25 PM
GetLeVeLed's Avatar
Default general suspension questions
Ok, I'm looking into suspension (just starting to do me research, so bear with me) to aide my general understanding. This is what I got so far; tell me if I'm right.
Dampers are called shocks only when they are installed separately from the spring (read: they are not the same unit, aka the shock is not inside the spring. more on that later). This means that if your shock snapped/broke (like mine did. more on that later), the car would still be suspended, since the spring would not be affected. You'd have one hell of a bouncy ride though since nothing would stop the spring oscillating. My right rear damper snapped before - midcorner bumps would send the rear up and to the side... fwd dorifto like whoa. This means I have a spring/shock system, right?
Then you have struts (as opposed to shocks). The difference is that the strut is inside the spring. This means that if the shock snapped/broke, that corner would be on the ground. You're f*cked and can't drive anywhere.
Now coilovers. These use struts, as the spring is "coiled over" the damper. Now this is where I hit a gray area. What's the difference between a regular spring/strut shindig and a coilover setup? I can see three although not all of them might be true. a) Coilovers can be adjusted; b) With coilovers the spring and the strut can't be separated, as opposed to a regular spring/strut setup where the spring and the strut are separate elements thrown together; c) coilovers replace the upper A-arm.
So:
1) Is what I posted above correct?
2) So what's the deal with the coilover question that I posted near the end of my speil?
3) Please post any suspension-related information/articles that you know of. I'd like to know all I can before I start shelling out money. This includes info on control arms, bushings, even roll bars (ok, anti-roll, technically, I know).
4) Whether a strut or a shock, the damper itself is the same thing, right? If you don't take into consideration its location in relation to the spring, that is.
5) If a car has a spring/shock setup, can it be switched to a spring/strut one, and vise versa?
Thanks!
Oh, and yes, I did search and I am actively searching. I've been reading plenty about suspension over the last few days but just want to clarify some points.
Old May 12, 2009 | 04:57 PM
TunerN00b's Avatar
Default Re: general suspension questions
Nope, you're way off, on several things.
Struts are shocks, in that they both damp suspension motion. The difference is only that a strut is also a structural suspension locating device, whereas a shock is not.
If you break a shock/strut, the car would not be suspended if the spring is over the damper. However, with a shock, the wheel would still be held in the correct location as all suspension arms would still be intact.
Either can have the spring around it or not.
And a "coilover" is a coil spring over the shock. Stock, most strut and shock based cars have a "coilover". The term is also frequently abused to only mean a threaded spring perch.
Old May 12, 2009 | 06:17 PM
Tyson's Avatar
lol. not worth reading.
Old May 13, 2009 | 07:49 AM
SOHCNightmare's Avatar
x2
Old May 13, 2009 | 10:10 AM
GetLeVeLed's Avatar
It wasn't meant as an informative post, its to help me understand suspension. You should follow TunerN00bs's example and actually try to help. Unless all your ~15000 posts are stupid bullshit flaming people, you should actually know a little about this stuff and should be able to help.
Old May 13, 2009 | 11:00 AM
Tyson's Avatar
every statement is wrong. its laughable. and really it just seems like youre talking technical semantics.
spring = that springy thing
shock = short for shock absorber
strut = part of a macpherson strut suspension.
macpherson strut suspension = the shock is integrated with the structural support of the suspension. the spring coils around the shock at the top. makes for a compact and robust suspension.
double wishbone = aka short-long arm SLA suspension. shock is not part of the structural support of the suspension. motion is controlled by the upper and lower control arms.
coilover = simply the spring "coils over the shock". misused to mean a fully threaded shock with integrated height adjustment.
divorced spring = not a coilover setup. commonly used in the rear where its more efficient to package the spring from the shock for more passenger room. see rear of VW's.
really man, where the **** did you come up with that crap? search wikipedia instead of just guessing.
Old May 13, 2009 | 11:12 AM
GetLeVeLed's Avatar
Alright, a useful reply. Thanks for that.
I read through the howstuffworks articles and some random forums and whatnot but those were filled with contradicting information.
blackeg
Suspension & Brakes
Sep 9, 2011 07:35 PM
RighteousMidwest
May 8, 2007 06:09 AM
XoUnKoWnXo
Jun 16, 2004 09:03 AM
teg92
Apr 25, 2002 02:04 AM
