Question on suspension
Old Apr 24, 2002 | 04:44 PM
teg92's Avatar
Default Question on suspension
I was under the assumption that the spring absorbs all the dead weight of a vehicle and the shock only dampens the oscillations. Well, I just noticed this pass week that the rear drivers side of my car is about 2" lower than my passenger. I just jacked it up and confirmed my suspision when I couldn't get the jack under! Well my car is out of comission and I'm trying to figure out if something other than a blown shock could be causing this. Thanks!!!!
Old Apr 24, 2002 | 04:51 PM
IN VTEC's Avatar
Default Re: Question on suspension (teg92)
Broken spring perch?
Old Apr 24, 2002 | 05:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Question on suspension (IN VTEC)
Either broken spring perch or maybe other damaged suspension components. Other than that I'm not sure.
Old Apr 24, 2002 | 05:11 PM
teg92's Avatar
Default Re: Question on suspension (PatrickGSR94)
Would I only be able to see a broken spring perch with the shock/spring assembly removed or could I see it with it installed? I glanced at everything and everything looked right. No chance of it being the shock?
Old Apr 24, 2002 | 06:02 PM
HondaJon's Avatar
You would pretty much be able to see a broken spring perch if you removed the rim/tire of the corner which you suspect. I really don't think that busted shocks would sag 2" but I'm not positive. Sounds like a spring problem, you have the stock springs????
Jon
Old Apr 24, 2002 | 06:48 PM
teg92's Avatar
Default Re: Question on suspension (HondaJon)
Ok well I probably exaggerated. Its more like barely 1 finger on one side and 2.5 fingers on the other.
Old Apr 24, 2002 | 08:26 PM
teg92's Avatar
ttt
Old Apr 25, 2002 | 02:04 AM
tonydatyga's Avatar
you talking wheel gap measured by fingers?? Gluck...
GetLeVeLed
Suspension & Brakes
May 13, 2009 11:12 AM
vinuneuro
Suspension & Brakes
Oct 19, 2007 01:52 PM
cheetah64
Apr 26, 2005 04:56 PM
euclid
Jun 10, 2004 07:33 PM
jweller
Nov 1, 2003 05:29 PM
