obd1 b16 swap into 97 dx civic
Old May 12, 2009 | 03:29 PM
k20rsx1's Avatar
Default obd1 b16 swap into 97 dx civic
alternator plug is diff what can i do? do i need a obd2 b series alt?
plan on rewiring dizzy so the obd1 will work... wires are all the same so that should be easily done !
also my harness is obd2 so the injector clips are diff is it easy to wire them?
Old Aug 21, 2012 | 01:58 PM
Tony Berndt's Avatar
Default Re: obd1 b16 swap into 97 dx civic
You can get a OBD2 dizzy or they make an adapter for the single to double dizzy plug. I bought the adapter and it works great.
You just need an OBD2 alternator, ran into the same problem here too.
Lastly its easier to get injectors off a OBD2 car but you can also splice (solder) connections from old harness. I chose to get different injectors.
Old Aug 21, 2012 | 02:00 PM
Your also going to need an EX wiring harness or you can wire the VTEC seperately. Depends on your wiring skills.
Old Aug 21, 2012 | 06:18 PM
HondaPartsHero's Avatar
Technical Hero
2drh22
Feb 26, 2009 06:09 AM
ATX45
Jun 10, 2006 06:24 PM
gunnis
Sep 19, 2005 06:53 PM
b20mike
Jul 29, 2003 07:25 PM
