'93 b18a jumped time
Old May 12, 2009 | 12:57 PM
memorybox's Avatar
Default '93 b18a jumped time
Just got this car, pretty cheap cause it jumped time, about half a cam gear. I replaced the timing belt and the car cranks and idles but goes dead when you give it gas. I see round marks on top of the pistons but i dont see any broken valve debris. Compression test shows 0 psi but Im not sure how good my gauge is, it is kind of old but has always worked
Will it idle without much compression? Do stock pistons have relief marks you can see through the sparkplug tunnel with a flashlight?
Old May 12, 2009 | 05:05 PM
mltv's Avatar
Default Re: '93 b18a jumped time
well on my 91 the pistons do have cut outs for the valves, the gague is it a compression gague or leak down gague? With the car engine on disconnect the sparkplug wire listen very closely to the sound the engine makes. unplug it listen to the sound or have someone check how low the RPMs bogs. Plug it back and move to the next. if there is no sound difference then thats a dead cyclinder. the one that has largest RPM drop when you disconnect it thats the one with the highest compression.
When you say that you give gas and dies? ARe you holding the pedal down or do you tap the gas pedal and then release---dies?
Old May 12, 2009 | 05:17 PM
sp00ledbseries's Avatar
you got bent valves at the least
Old May 12, 2009 | 06:37 PM
memorybox's Avatar
Would it run if I timed it on the wrongstroke? It does nothing if I tap the gas. Dies if I floor it. Ima time it 180 out and see if it works before I say bent valve
Old May 13, 2009 | 01:02 PM
memorybox's Avatar
Re-timed it, car runs great thx
memorybox
May 13, 2009 01:01 PM
realis9
31
Apr 3, 2007 06:13 PM
tarheeler
May 28, 2005 06:10 AM
95c1v1cs1
Apr 21, 2003 11:29 AM
Chuji
Oct 30, 2001 07:26 PM
