ITR rear lcas work with asr endlinks of an ej1??
OMG it'Z McFLY!
This may be a stupid question..but i recently bought the asr brace and sway bar combo off my buddy with an ej1 (eg) and it came with endlinks. will these endlinks work with my rear itr lcas? any help is appreciated. thanks
ASR would probably be the best place to get your answer, since they made the product. Did your buddy have stock EG LCAs? I think the answer might be "No, they won't work" (if they were made for EG LCAs) but I am not positive, and haven't tried it myself.
Put a dc lca. If the endlinks are adjustable. Yes you can. I'm currently running civic 99 ex yellow with dc lca (a little bit of grinding to fork mount to fit) with adj endlinks. Stock ones was to long to mate together. Don't ask why I went to trouble of doing it. It was extra parts lying around the garage.
If the question is for me. I'm using blox dc lca using 99 yellow. Help a lot with tire rub on 15's hoosier, adj endlinks and grinding the fork mount. Brought the tire in. Running crazy offset.
Wait....what? You mean you're using a Blox DC Integra LCA with '99 Civic Koni Yellow shocks on...what car? And what does "brought the tire in" mean, unless you mean you're running a very high offset wheel ("crazy offset?"), but then how are you not rubbing on everything in the wheel well?
i didnt mean to steal the thread. let me just write down what i did. now remember this parts are what i have in the garage. parts are going to 98 itr replacing mugen shock and springs (another subject)
itr oem springs.
itr oem top hats.
99 ex coupe koni yellow (set on lowest height.).
dc blox lca (grinding on both side of fork mount.)
blox adj.
35+ offset te37 wheels.
hoosier 205-50-15
waiting on camber kits and wheel alignment.
itr oem springs.
itr oem top hats.
blox adj.
hoosier 205-50-15
Ok, so now that you have all those parts listed, what does it have to do with ASR endlinks bolting up to ITR LCAs? You have neither of those parts on your car.
drkstrs24
11
Jun 11, 2010 03:00 PM
NiceDc2r
Suspension & Brakes
Mar 18, 2005 07:27 AM
