fastcody's recent work
Old May 11, 2009 | 07:19 PM
fastcody1's Avatar
Default fastcody's recent work
Here's some work i've done recently after work
this is my brothers mustang with stock ls2 76mm turbo w T6footprint
heres a wrx downpipe back 3" no muffler
Old May 11, 2009 | 07:43 PM
JDM KID 510's Avatar
Default Re: fastcody's recent work
Nice Work.
Old May 11, 2009 | 07:52 PM
skylinepowered240sx's Avatar
Very nice!
Old May 11, 2009 | 07:55 PM
-RedneckDave-'s Avatar
Working
Some nice work there. The ls2 in the mustang is interesting for sure.
Old May 12, 2009 | 03:48 AM
ELSpool's Avatar
The exhaust is going to have some bark to it!
Old May 12, 2009 | 06:30 AM
champLSinteg's Avatar
Nice! I am working on a single turbo mustang also. One question...why do you need a flex on the crossover pipe? I am going to make a support for the turbo but every set up I see has a flex on the crossover pipe.
Is this not running a swaybar?
Old May 12, 2009 | 08:20 AM
redboost10's Avatar
we did a single turbo on a fox body about a month ago, we did not put a flex pipe on the cross over and its doing just fine. we just used 2.5" 16g mild steel.
with those cast manifolds i dont see them expanding with heat so the cross over pipe shouldnt really need a flex pipe but its good insurance.
we made 16g headers for our customer and still didnt use a flex pipe on the crossover, the turbo is mounted to the midplate.
Old May 12, 2009 | 08:33 AM
fastcody1's Avatar
He doesn't have solid motor mounts, and the T6 flange is welded to the frame. this is going to be a street car so I see the flex pipes as insurance.
He will be running a sway bar.
Old May 12, 2009 | 08:41 AM
96supercharged's Avatar
Chevy engine in a ford chassis. The car gods will hate you for all time.
Other than that, awesome
Old May 12, 2009 | 08:45 AM
Nick Z32's Avatar
is the pipe galvanized?
Old May 12, 2009 | 09:36 AM
fastcody1's Avatar
lol you take the light car and put a good engine in it. it should be fun
NICK Z32
it's aluminized exhaust pipe
i told him to get mild from crmb but i think he gets a good deal from wynne
Old May 12, 2009 | 09:50 AM
That is what I am doing right now. I am using his BBK shorty headers but I will support the turbo. So the flex pipe is used in this case for heat expansion? I was trying to figure out why it was used when everything is bolted to the block and it will move with it.
More pics! That turbo is huge compared to the sc61 we are using! LOL
Old May 12, 2009 | 10:58 AM
fastcody1's Avatar
more pic's to come
i used the flex sections because the turbo is going to sit still while the motor and headers move back and fourth im not worried about heat expansion
Old May 12, 2009 | 12:28 PM
redboost10's Avatar
yeah if the turbo is bolted stationary, the cross over pipe shouldnt need a fles section, even if the headers are tubing as well...well so far i can make this statement, haha. we are running a midplate so there are no motor mounts and im assuming heat expansion will be limited so not too worried.
looks good fastcody
Old May 12, 2009 | 03:14 PM
Only if the turbo is bolted stationary to the block. In this case the flange is welded to the frame so you need one to flex when the motor torques.
Old May 12, 2009 | 05:31 PM
redboost10's Avatar
yeah you will need a flex pipe, or at least it would be a good idea.
with a midplate it dosnt matter at all. the only worry there is thermal expansion which we havnt had a problem with. sorry to be so confusing
BACKintheDA
Jun 14, 2006 11:07 AM
evilm
Nov 13, 2003 10:11 AM
MR. Klein
Jan 27, 2003 03:23 PM
