flywheel question
Old May 11, 2009 | 05:57 PM
Slow_import's Avatar
Default flywheel question
i was trying to knock off the 3 pins on my flywheel so i can take it in to get it serviced and they broke on me.
just wondering if those are a must have on the flywheel or not?
I was told not to worry about it, but just wondering what you guys would think.
Old May 11, 2009 | 07:59 PM
racebum's Avatar
Default Re: flywheel question
they make sure you put the pressure plate on correctly. if you are careful and line the holes up correctly again everything will work right. without the pins you can install the plate off and the balance will also be off. there is no reason to ever remove those pins
LU!SKEY
Dec 19, 2010 11:48 AM
remaxxxk
Mar 1, 2006 09:11 PM
Revi
Jun 7, 2004 07:57 AM
StolenTeg
Mar 5, 2004 12:54 PM
