Lowered Car...Remove Wheelwell?????
I just wanna make sure im not the only one thinkin or did this. Im riding on H&R sports, AGX's and ended up being lower that I thought. When I have a passenger It rub real bad. So im thinking of removing my wheel wells. Is its ok to do so thx.
P.S. Ive searched...So all the ones that are going to mention the search bar, please save it THX
are you talking about removing the fender liners? if so, then yes, it's ok to take them off. i took them off in my gsr because the wheels would rub the clips on turns. the only issue you'll have is dirty door jambs.
removing the liners wont make yur ride smoother, its so the tires wont rub on them mainly when yur turning, cuz by those springs i know yur not slammed, cuz im lowered 2.5 inches and i only rub on full lock to lockl turning,
what size rims do u have???
Im running on the the stock 15" LS mesh. Its really bad when i have a passenger. I ended up hammering some of that metal that get in the way of my tires. I hope that will do
I had H&R Sports while running 205/50-15 tires, and I never had problems with rubbing up front. Yes they were lower than they should have been, and were not stiff enough, but I didn't have any problems and have ALWAYS had the fender liners in on my car.
Are you sure that's where it's rubbing? Did you install the springs in the right place (front springs in front and rear in the rear)?
sombasol
Jun 19, 2003 09:35 PM
