Distributor leaks!..MAJOR! NEED HELP!..
Old May 11, 2009 | 03:52 PM
s0lefreshh's Avatar
Default Distributor leaks!..MAJOR! NEED HELP!..
I have major oil leaks dripping out from the bottom of my distributor cap..not sure whats the problem..i took off the distributor and screwed off the cap and oil seems to leak into the distributor..so i replaced it with a extra distributor i have laying around my house..screwed everything back on and started the car..it seems to have stop for about 2-3 minutes, but then it starts dripping out oil again..so im stuck to the point where im not sure what to do..not sure if i want to go buy a new distributor and have the same problem..any advice will be greatly appreciated...thanks
Old May 11, 2009 | 03:57 PM
RunninEg6's Avatar
Default Re: Distributor leaks!..MAJOR! NEED HELP!..
the distributor o-ring is probably worn. pull it out again and change it. couple $ at honda
Deetz's Avatar
Crazy Honda Guy
did you replace the 99 cent o ring that goes on the dizzy shaft??
Old May 11, 2009 | 04:00 PM
s0lefreshh's Avatar
yep, o ring was replaced..
Old May 11, 2009 | 04:04 PM
Former User's Avatar
In addition to the shaft O-ring, there's a seal inside the dizzy that, if bad, will allow oil into the dizzy.
Old May 11, 2009 | 04:23 PM
s0lefreshh's Avatar
^thanks bro..im going to check that..
ribal_gh
Nov 10, 2012 10:00 AM
Cameron k.
60
Sep 25, 2012 07:19 PM
jchrm80
May 17, 2009 09:27 AM
blackeg
Mar 13, 2009 09:58 PM
porsche997dc2
Dec 22, 2003 08:49 PM
