low oil pressure
k i have a boosted dohc zc and with a brand new oem oil pump and for some reason i think im getting low oil pressure....
i was driving on the highway today and noticed i was only getting 35psi at 4k
and then when i did a pull in 2nd gear...at 7k im only getting 40psi....
after driving it hard and when i put it in neutral to idle the oil dummy light will flicker....ive checked the connection and its all good...but once i start driving again the light will stop flickering...
im running 10w30....could that be the reason ?
its starting to hit summer so its around 80-90 degrees....
eg6madness
Sep 26, 2008 02:32 PM
