low oil pressure
Old May 11, 2009 | 12:56 PM
ll3o0sTeD's Avatar
Default low oil pressure
k i have a boosted dohc zc and with a brand new oem oil pump and for some reason i think im getting low oil pressure....
i was driving on the highway today and noticed i was only getting 35psi at 4k
and then when i did a pull in 2nd gear...at 7k im only getting 40psi....
after driving it hard and when i put it in neutral to idle the oil dummy light will flicker....ive checked the connection and its all good...but once i start driving again the light will stop flickering...
im running 10w30....could that be the reason ?
its starting to hit summer so its around 80-90 degrees....
Old May 11, 2009 | 01:19 PM
Running925's Avatar
Default Re: low oil pressure
sounds like you've developed bearing failure.
better pull the pan & take a look.
young geezer
Oct 13, 2011 07:07 PM
Retribution
Apr 1, 2009 06:22 PM
eg6madness
Sep 26, 2008 02:32 PM
xlee08
10
Apr 1, 2008 02:00 PM
EARLdaSQUIRREL
Sep 2, 2007 04:40 PM
