pull a check engine light
Old May 11, 2009 | 11:52 AM
turboef90's Avatar
Default pull a check engine light
alright when i jump my service connector i dont get nuttin but i know my ecu is good. so do i ground d4 off the ecu??? o ya its obd1
Old May 11, 2009 | 01:02 PM
turboef90's Avatar
Default Re: pull a check engine light
bump
Old May 11, 2009 | 01:28 PM
rustbucketrex's Avatar
Need more info: OBD0-OBD1 jumper harness? If so, you need to connect the blue wire to the orange wire(Rywire harness) or use a switch to read your codes.
Old May 11, 2009 | 01:34 PM
turboef90's Avatar
ya its one a obd0 to obd1 jumper. not sure of who make the harness. its not a ebay one tho. which pins would i put the switch in between tho?
Old May 11, 2009 | 01:36 PM
Are there 2 wires that are not hooked to anything coming out of the jumper?
Old May 11, 2009 | 01:47 PM
turboef90's Avatar
here what i cut. i had a shop do the jumper. i guess my old one was ****ed. well i started takin tape apart etc. and found this. i know this isnt good. i had this done awhile ago also. my car is going in to safe mode going down the highway.
Old May 11, 2009 | 02:07 PM
Sorry, that's above my paygrade and limited knowledge. Maybe someone else can chime in. Good luck
Old May 11, 2009 | 02:43 PM
turboef90's Avatar
lol i got it figure out already. the wire that went to b20 wasnt hooked up hook it up and where your spose to jump it under the dash works fine now thanx tho
spoon93
13
Dec 31, 2011 06:59 AM
akurtzer57
Engine Management and Tuning
Aug 2, 2010 01:20 PM
craig88crx
May 30, 2010 08:17 AM
91highryda
Oct 6, 2007 08:24 AM
turborex2
Jul 22, 2005 07:13 AM
