Del Sol has no turn signals or dash lights.
Old May 11, 2009 | 01:45 AM
TwoKSiR's Avatar
Default Del Sol has no turn signals or dash lights.
I'm not sure if it's related or two seperate things. THere's no backlights on the cluster or climate control and stuff. I bought the car this way and I'm just rying to get it put back together. All the fuses are good. There was no turn signal relay in when I got the car. I got one and threw it in. When you hit the turn signal you can hear the click but the light on the cluster doesn't come on and the corners.
I'm guessing the backlights are another issue. But where should I start looking to fix that? Again the fuses are good.
Old May 11, 2009 | 04:51 AM
Former User's Avatar
Default Re: Del Sol has no turn signals or dash lights.
For the dash lights, a common problem is the dimmer switch. Check whether jumping the red and black wires in the dimmer switch connector restores the lights. If so, replace the switch.
For the turn signals, do the hazard lights work?
Old May 11, 2009 | 05:59 AM
TwoKSiR's Avatar
No the hazards don't work.
Old May 11, 2009 | 06:02 AM
Both the turn signals and hazards require the hazard switch to work. Make sure the plug behind the hazard switch is tightly connected.
Vmates
Jun 28, 2018 04:41 AM
Silvertune
11
Apr 15, 2012 09:20 PM
BoostedAccord95
20
Jun 5, 2011 02:21 PM
TwoKSiR
May 19, 2009 10:13 AM
