84 mm Gsr block with b16 head
Old May 10, 2009 | 05:50 PM
stefz's Avatar
Default 84 mm Gsr block with b16 head
hey guys just wondering if i could get a gsr block resleve it and bore it to 84 mm, and still run boost, im looking to get a CR around 10.5 bc im not running more then 15 psi... any thoughts or advice is great
thanks
Old May 10, 2009 | 06:45 PM
kingofbattle909's Avatar
Default Re: 84 mm Gsr block with b16 head
ya nawt meking n e sense mon...
Old May 10, 2009 | 07:01 PM
h22ed6's Avatar
ya you can do it but I would lower the comp. a little more
Old May 11, 2009 | 03:18 AM
stefz's Avatar
ok how much would it lower it and how could i bump it up?
Old May 11, 2009 | 03:42 AM
cintegra98's Avatar
I would go with a 9:1 compression, Some pistons use like a 9:8 compression but I would be careful. Once you feel that 15 psi your going to want more, 10:1 might be a little much if you are daily driving it.
Old May 11, 2009 | 05:32 PM
h22ed6's Avatar
I would go like 9.5:1 or 9.8:1 that will give a good spool for it and it will be good for daily driving
Old May 13, 2009 | 12:09 PM
stefz's Avatar
the car will only be driven on the weekends... with a b16 head would compression increase or deacrease bc im getting mixed answers, and i want to keep it near stock CR so i wont lose when im off boost
Old May 13, 2009 | 01:03 PM
Garage 808 Hatch's Avatar
B16 head will drop your compression from a gsr head by about .2-.3
Old May 14, 2009 | 11:23 AM
stefz's Avatar
so if im looking for to around 10.2-10.5 Compression i look for something around 10.6 for a gsr with the bore of 84 mm
Old May 14, 2009 | 11:53 AM
LA_HONDAS's Avatar
how much power your looking for?
Old May 14, 2009 | 12:01 PM
stefz's Avatar
i dont have anypower goals its juss my weekend car but im not going to be boosting it till next year so thats why im going with the high compression
hatchet_honda
Jul 6, 2009 09:27 AM
civcexcoupeblack
Jan 23, 2005 08:20 PM
mR. Vash
Nov 20, 2004 01:58 AM
boostin4door
Jul 27, 2004 08:46 AM
X2BOARD
Nov 7, 2002 04:37 PM
