Reverse lights never worked...
Old May 10, 2009 | 05:20 PM
Canadian_EF's Avatar
Default Reverse lights never worked...
I checked the bulbs today, and they are still good. The reverse lights do not come on when put into reverse. Can this be caused by simple corrosion of the wires? Where should I check for this? i.e what is the most common place?
many thanks...
Old May 10, 2009 | 05:23 PM
rattlecannedEF's Avatar
Default Re: Reverse lights never worked...
im also wondering the same thing.
an easy fix is to run a pos and negative off the battery into a switch into a bulb., then flick the switch when you throw it into reverse.
its a pita but its better than nothing.
black0hatch's Avatar
are the wires hooked up at the tranny?
Old May 10, 2009 | 05:29 PM
Sidewayz_240's Avatar
Was your car converted from auto to manual? If so than thats why.
Old May 10, 2009 | 05:32 PM
Real Ek4's Avatar
My car is manual OEM D16A9 (ZC) and i have the same problem.
Old May 10, 2009 | 05:33 PM
rustbucketrex's Avatar
Or if the wiring harness was switched for some reason, some models were set up differently(thats what I ran into with a DPFI-MPFI swap harness and had to repin the drivers side connector to make them work).
Old May 10, 2009 | 05:34 PM
how do you get to the wires at the tranny?
Old May 10, 2009 | 05:39 PM
Right next to the O2 plug in your wiring harness, 2 wires black/green and yellow I think.
Old May 10, 2009 | 06:18 PM
as far as i know, this is the original engine...
i am a super-noob... where is the wiring harness? pictures are great.
Old May 10, 2009 | 06:30 PM
4DRmafia's Avatar
I have the same problem but mines is different. When I turn on my car and the reverse is not in gear, the light stays on through all gears and even neutral. When I slide in reverse, it will turn off and then back on. When I take it out of reverse, it cut off and then back on. So, it stays on until I turn off the car. I'm thinking switch is bad. Easy fix prolly. I hope.
Old May 10, 2009 | 07:27 PM
~sp33~'s Avatar
EFB055
Theres a switch at the transmission that will send power to the lights when it detects reverse has been selected. It's likely that the wires have simply come loose at the switch. What's less likely is that you'll have to replace the switch.
Old May 10, 2009 | 08:05 PM
Zaakro's Avatar
I had a weird problem where the switch was good, new bulbs, the bullet plugs were connected, and I tested the wiring all the way to the bulbs and it was all work. And my reverse lights have never worked for me for the 4 years I have had the car. My trunk light in my hatch has never worked either. It would only flicker on when I opened the hatch. So I took the hatch lock off and found out it wasn't grounding right for the trunk light to turn on. I fixed the grounding problem with the trunk light and it was working like it should. The next day I noticed that my reverse lights started to work
Old May 10, 2009 | 08:11 PM
so your saying if we replace the grounds it might work?
ill give that a shot tomorrow and post my findings
Old May 10, 2009 | 08:18 PM
my trunk light doesn't work either... hmm............
i think that this should be added to the faq.
blackfoot
Nov 6, 2007 04:10 PM
premo_si
Apr 29, 2006 12:44 AM
silver00teg
Feb 18, 2005 12:42 PM
93jdmsi
Dec 29, 2002 01:30 AM
Sloth
Nov 27, 2001 11:13 PM
