Did i hook up my WG/BOV/gauge right vaccum/boost spots ?
Is this how my boost/vacuum is suppose to be hooked up?
right now i have,
boost gauge+bov hooked up to the same port on intake manifold BEFORe throttel body.{bellow TB as its D16Y7 INTAKE MANI}
botom port of WG to the compressor housing
Top port of WG open to atmosphere,
is the following correct or no ?
right now i have,
best thing to do is a vac log if you can. if you cant, tee the bov into the pcv line, boost gauge into the fuel pressure reg line.
the wastegate is correct as long as you are only running wastegate spring boost.
90AcuraIntegra04
Jan 28, 2006 07:02 PM
livinlow
Mar 15, 2005 09:21 PM
paulzy
Dec 23, 2001 05:47 PM
