B16a2 swap question
Old May 10, 2009 | 09:25 AM
NoLeftTurn's Avatar
Default B16a2 swap question
What else do i need to finish this swap in an ek? Like, will my shift linkage work? What axels should i use?
Old May 10, 2009 | 10:14 AM
BigAnteg's Avatar
Default Re: B16a2 swap question
everthing is direct bolt on the axles the shift linkage motor mounts wire harnes the only thing u would have to do would be wire up the vtec if it is not a ex or has the vtec wires already their
Old May 12, 2009 | 07:38 PM
NoLeftTurn's Avatar
how about ecu? I heard if i use the 99-00 si ecu i will throw a fuel tank pressure code. and if i run a obd2 p72, i might throw a vtec code because of the secondary runners on the gsr manifold.
laperriere
Apr 4, 2012 06:09 AM
Tito559
10
Feb 8, 2011 02:29 PM
charlieboyhonda
Dec 3, 2007 10:06 PM
civickid5835
Apr 14, 2006 12:06 AM
SpiritUnreal
May 1, 2003 09:54 PM
