B16a2 swap question
Re: B16a2 swap question
everthing is direct bolt on the axles the shift linkage motor mounts wire harnes the only thing u would have to do would be wire up the vtec if it is not a ex or has the vtec wires already their
how about ecu? I heard if i use the 99-00 si ecu i will throw a fuel tank pressure code. and if i run a obd2 p72, i might throw a vtec code because of the secondary runners on the gsr manifold.
charlieboyhonda
12-03-2007 10:06 PM
