Auto Trans?
Old May 10, 2009 | 09:22 AM
webba1's Avatar
Default Auto Trans?
My wife's 97 LX just ate the transmission. I've found a replacement but it's out of an EX. Are these a direct swap? Anyone ever done this? Does anyone know what the gearing ratio's are and if they're different? Will I run into any problems with the ECU wanting to shift the transmission earlier or later than it should?
Ideas, suggestions, anything will help...
Yes I did search.
Old May 10, 2009 | 09:39 AM
94EG8's Avatar
Seagull Management
Default Re: Auto Trans?
So far as I can tell there are 2 different automatic transmissions for '96 - '00 civics and they seem to differ based on the year rather than the model. If its from a '96 - '98 it should work fine, even if its from a '99 - '00 I still highly suspect it will work, if its from a '92 - '95 it wont work.
Old May 10, 2009 | 02:53 PM
webba1's Avatar
Thank you much!!! After looking at hondapartsdeals.com the EX and LX have the same final drive gear part number. Traditionally, the final drive gear is the main difference between EX and any other trans so I think you're probably right on the money!!!
Mason Edmison
Dec 22, 2019 09:45 PM
Boosted.Ctr
Transmission & Drivetrain
Aug 4, 2012 04:02 AM
dempsi
Aug 13, 2011 05:49 AM
hysteria411
May 19, 2010 03:49 PM
