Big swap! Have you seen this?
Old Aug 17, 2002 | 05:05 PM
crxcess's Avatar
Default Big swap! Have you seen this?
Sorry if it is a repost. Still, a repost worth seeing.
Owner/Builder
Eddie of Rockville Center, NY
Curb Weight
3200 lbs (stock CRX is about 1800 lbs)
Powertrain
Front: Completely Stock and Functional Honda CRX 4-Cylinder Engine (front wheel drive)
Front Engine Drives Air Conditioning, Alternator and Water Pump
Rear: 468 cubic inch Oldsmobile V8, roller cam, 4-71 supercharger
Hilborn 4-port fuel injection
Separate Gas Pedals (one is a flip down)
Shifters for Each Engine
Fuel
Front Engine: Standard Gasoline
Rear Engine: Racing Gas (CAM2)
Three Fuel Tanks - Two for the Front Engine, a Single Five Gallon Tank for the Rear
Drivetrain
Front: Stock Honda Automatic Tansmission
Rear: Toronado Turbo 425 with 10" Racing Converter and 3.08 Gear Ratio
Cooling System
One Radiator in Front for Both Engines - Coolant Supplied via Common Piping System
Exhaust
Front: Stock Honda Single-pipe Exhaust
Rear: Zoomie Headers (Straight Pipes)
Suspension
Front: Stock Honda Front-End Suspension
Rear: Coil Over Independent
Tube Chassis Built from the Firewall back
Wheelie Bars
Tires
Rear: 15" Mickey Thompson Street Tires
Performance
No formal time tests have been made yet, but owner estimates 0-60 in about 2-2.5 seconds, 1/4 mile at 9.25 and 160 mph on about 1000 HP. It handles perfectly straight up to 130 mph - top speed so far. This car does NOT sit in the garage and look pretty. It drives around town and looks "surprisingly normal." That is, until the rear engine is fired up...
here is the actual link.
http://www.mothers.com/coolcars/cust...dies84CRX.html
[Modified by crxcess, 2:06 AM 8/18/2002]
Old Aug 17, 2002 | 05:13 PM
spoonef's Avatar
Default Re: Big swap! Have you seen this? (crxcess)
oh man thats crazy i want to see it on the strip
Old Aug 17, 2002 | 05:16 PM
Losrocket_'s Avatar
Holy crap!!! That is the craziest swap ive ever seen. to him for building it and driving it everyday.
Old Aug 17, 2002 | 06:15 PM
racerxadam's Avatar
where does the trans go. it should be sticking out the back of the car like three feet. I would like to see this in person
Old Aug 17, 2002 | 06:20 PM
MilanoRex's Avatar
Default Re: Big swap! Have you seen this? (racerxadam)
i want one
Old Aug 17, 2002 | 06:45 PM
Freakn8's Avatar
Default Re: Big swap! Have you seen this? (MilanoRex)
seen it, it ruins the whole idea of a rex IMO
Old Aug 17, 2002 | 06:46 PM
crxcess's Avatar
hmmmm, yeah. where is the tranny? and the intake? does he just leave the windows down when he's drag racing?
Old Aug 17, 2002 | 06:55 PM
Louie B.'s Avatar
the oldsmobile toronado was a front wheel drive, V-8 equipped car, so the tranny is basically under the motor. and the intake is sitting right on top of the supercharger so it sucks its air from the passenger compartment.... better have the windows open!
[Modified by thumpu77, 8:01 PM 8/17/2002]
Old Aug 18, 2002 | 01:01 AM
Brandon Chun's Avatar
Default Re: Big swap! Have you seen this? (thumpu77)
I've seen that one before, still a good post up tho
Old Aug 18, 2002 | 06:53 AM
SiR Kid's Avatar
New User
Default Re: Big swap! Have you seen this? (Brandon Chun)
Talk about needing some earplug inside the car... I'll bet he'd go deaf if he fired up that charger without the plugs.
Old Aug 18, 2002 | 09:40 AM
marty's Avatar
Default Re: Big swap! Have you seen this? (SiR Kid)
i think its BS.. no way you can fit a Olds V8 and tranny and 3 fuel tanks in that car with the interior still in tact like that.
Old Aug 18, 2002 | 09:48 AM
kikicamacho's Avatar
If it's not bs, I like the idea of having both engines in the car for driveability. But that only works in theory. The added weight of the rear engine, tranny, and axle being lugged around by the 4 cyl engine up front, when the rear engine isn't "Fired Up" makes this car slower than grass growing. When the rear engine is running, I don't think a CRX radiator would be enough to cool it. I'm not saying it's BS. It just doesn't look practical to me.
Old Aug 18, 2002 | 10:24 AM
TONEBONE's Avatar
No, this thing is for real it was in car craft years ago. I have been looking for a pic of this car forever!! thanks
Old Aug 18, 2002 | 11:00 AM
daniel89civ's Avatar
Default Re: Big swap! Have you seen this? (jcamacho)
Old Aug 18, 2002 | 02:24 PM
.nate's Avatar
Default Re: Big swap! Have you seen this? (daniel89civ)
Note that it is on the Mother's website... theyre a reputable company -- I doubt its fake. Props!
EDIT: On a related, but unimportany note I came very very close to putting a 350 in the back of a 1st gen rex... but then Im just insane anyway
[Modified by N8, 5:25 PM 8/18/2002]
Old Aug 18, 2002 | 07:16 PM
Mr.JaCkeL26's Avatar
Default Re: Big swap! Have you seen this? (MugenEF7)
wtf!!!
Old Aug 18, 2002 | 07:27 PM
pagong's Avatar
i think they actually had the car on one of the episodes of Horsepower TV!!! dont know if the same one though.
Old Aug 18, 2002 | 07:56 PM
Civic89's Avatar
I believe that would be a NO ****! He say's no where that he's running a "stock" crx Radiator and HIGHLY doubt he is.
GreenHornet1212
Honda Insight & CR-Z Hybrid
Nov 8, 2013 08:58 PM
Mrpagani
May 13, 2013 05:07 AM
Vtechology
Nov 17, 2004 07:07 AM
CRVEF8
Oct 22, 2004 07:56 AM
zero2sxity
Oct 12, 2003 11:26 PM
