need to find obd2a to obd2b jumper harness
does anyone know where i could find an obd2a to obd2b jumper harness for my 99 integra...
i did a ls swap to my gsr cuz my gsr motor was mested up. so after swapping the motor i used my gsr ecu and now the car wont start. everything was done right. im using the gsr wiring harness. so any help would be good. thanks for your time
Rywire for conversion harnesses.
You're leaving out a lot of important details. If you have a '99 Integra, why do you need anything to do with OBD-2b? If "everything was done right," then why are you using a P72 ECU with a B18B engine?
www.jdmshit.com has an obd2b to obd2a but not the opposite...idk where you could get that. IMO get a obd1 jumper and obd1 ls ecu and be done with it.
shadykit
May 12, 2004 09:48 AM
