Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Why is my overflow tank empty when engine is cold ? UPDATE
Old May 9, 2009 | 03:39 PM
wangan's Avatar
Default Why is my overflow tank empty when engine is cold ? UPDATE
Is it normal ?
Rad is full, no over heating.
Absolutely no problems whatsoever.
Been driving car like this for over a year.
Old May 9, 2009 | 03:47 PM
TOO MUCH TORQUE's Avatar
Default Re: Why is my overflow tank empty when engine is cold ?
probably during the coolant flush, whoever did it, didnt top off as the air bubbles were rising
Old May 9, 2009 | 03:49 PM
wangan's Avatar
So what do I do.
Add a little prestone till its between min and max ?
Old May 9, 2009 | 03:50 PM
1992Si's Avatar
Normal, just top it off to the cold line when it's cold and keep on eye on it for a couple of weeks.
Remember 50/50 mix.
Old May 9, 2009 | 03:54 PM
wangan's Avatar
Cool im gonna buy some Honda Anti-Freeze that is pre-mixed...but i dont have a cold line just a min and a max...should i fill it till its in between?
Thanks guys
Old May 9, 2009 | 04:00 PM
stevenDAtegra's Avatar
Thanks guys
It's almost always better to buy straight antifreeze. Mixed often costs more, and you're getting less. It's basically like buying watered down coke. Distilled water is really cheap and some say you can even just use good tap water if your area doesn't have a lot of minerals for 50/50 mix
I beleive the cold line is in the radiator? It's the lip in the radiator at the top
Old May 9, 2009 | 04:01 PM
wangan's Avatar
Yeah but my rad is already full.
Thanks
Old May 9, 2009 | 04:33 PM
1992Si's Avatar
I would go to the min line and watch it for a couple days when it cold and hot.
They say you can leave tap water out in a bucket over night and it's ok to use use it as the mix if you have hard water, IDK, that's what I heard years ago.
I've alway's just used my water out of the tap. I have well water and it's not hard.
Either way, I don't think it really makes a difference. There's enough lub in good anti-freeze. Do you plan on keeping the car forever and never replacing the water pump...
Old May 9, 2009 | 04:41 PM
you will be able to get by with just distilled water. i flushed mine with 50/50, ran out of that and just filled the rest with distilled water(1/2 gallon)
Old May 9, 2009 | 05:12 PM
wangan's Avatar
Can i mix my green coolant with the new blue type 2 coolant honda has ?
Old May 9, 2009 | 05:31 PM
TruNinja619's Avatar
^yea that's fine.
Old May 9, 2009 | 09:56 PM
DynastyRacer22's Avatar
try water wetter people say that stuff works pretty good but since your in the process give it a try
Old May 16, 2009 | 05:10 AM
wangan's Avatar
Okay guys I filled my reservoir between the max and min line.
Put about 350ml in it...now after 40 miles it dropped to min level.
WTF is wrong ?
Car is not overheating nor is it leaking.
Thanks
Old May 16, 2009 | 05:51 AM
toyomatt84's Avatar
Sanji
WTF is wrong ?
Thanks
It's probably burning it then. Possible headgasket leak.
Old May 16, 2009 | 03:45 PM
jdmfreak1992's Avatar
Default Re: Why is my overflow tank empty when engine is cold ? UPDATE
I don't know if you have changed you coolant lately but the drain plug on the radiator is plastic so it can be easily damaged or cracked over time. You said it's not leaking so It's probably not that but you might want to look at it just to be sure I always like to double check things. But if it's not leaking and It's still disappearing matt is probably right it must be being burnt off.
Old May 17, 2009 | 05:30 AM
wangan's Avatar
Could it be happening because my heater core and my ac compressor weren't 100% full.
Car has 44K can it really be the headgasket at such a low mileage ?
Thanks
Old May 17, 2009 | 08:55 AM
toyomatt84's Avatar
Sanji
Thanks
Headgaskets can blow at any time, for almost no reason at times.
JaguarS4R
12
Feb 28, 2010 04:12 PM
vic_houston
Jan 3, 2008 08:59 PM
cloven
Feb 18, 2006 07:06 PM
Arsenal
Dec 7, 2003 10:43 AM
senpai
Oct 28, 2002 11:32 AM
