need help code 23?
Old May 9, 2009 | 02:59 PM
Japankid's Avatar
Default need help code 23?
it has 2 slow and 3 fast check engine light
on a obd 1 92 civic with a b-seres
can it be the Code 23 Knock Sensor ??
Old May 10, 2009 | 08:22 AM
Japankid's Avatar
Default Re: need help code 23?
over 20 Views no input
Old May 10, 2009 | 12:42 PM
KWayRacing's Avatar
COde 23 does mean that there is a problem with the knock sensor or its input to ECM.I would start by checking that it is plugged in/ Maybe disturbed by oil change/recent work. The check that it is tight in the block. then check continuity to to the ECM connector D Pin#3. If all is good then replace the knock sensor. Good Luck and follow up.
T--Rex
May 14, 2005 07:40 PM
noob23
Aug 27, 2004 03:59 PM
99spanishGT
Mar 26, 2004 12:40 PM
roadawg
Feb 21, 2004 09:31 AM
