my boosted LS sonds kinda like all motor?
Old May 9, 2009 | 04:06 AM
northemt88's Avatar
Default my boosted LS sonds kinda like all motor?
whats up peeps,so i have a 89 crx with a b18a with a turbo kit.this last week my car has been running real good.so one day i go to the hospital then when i leave im driving down chula vista,my car started bogging,but only when im like at 10% throttle.then when i hit boost it felt weak,still hits 8 pounds on the gauge but does not feel like it.....when ever i come to the high rpms the motor gets louder then the turbo,it used to never do that.
i have only done a brief inspection of the couplings and stuff,all vacumes are good only have 2 vac lines the rest got blocked off.It is obd0 with stock ecu and fmu with a missing link,and a 255 fuel pump.
thanks for your time.
Old May 9, 2009 | 09:09 AM
lsvtechatch92's Avatar
Default Re: my boosted LS sonds kinda like all motor?
FMU = **** motors up!
Old May 9, 2009 | 11:43 AM
northemt88's Avatar
i know they do, but it runs good
it was not chopy of nothing
Old May 9, 2009 | 11:53 AM
gsrauto98's Avatar
Stock ecu? Is this tuned at all, if not get it tuned asap, before you blow the thing up
Old May 9, 2009 | 03:12 PM
crx6662's Avatar
I had a fmu. They suck. Check the fuel filter thats what mine was. Get it tuned. Fmu gone and get rid of the. Missing link and you will be golden
Old May 10, 2009 | 08:15 AM
northemt88's Avatar
Originally Posted by crx6662
I had a fmu. They suck. Check the fuel filter that's what mine was. Get it tuned. Fmu gone and get rid of the. Missing link and you will be golden
i been untuned for six months,it ran good.but saving money for some 550cc and some AEM standalone.so you said your fuel filter was your problem?you think you could post up some of your symptoms?
Old May 10, 2009 | 10:15 AM
AJxr's Avatar
motor is louder then the turbo? you mean like knocking noise?
my turbo ls felt sluggish but would still build 10psi... ended up spinning a rod bearing shortly after.
Old May 10, 2009 | 11:02 AM
northemt88's Avatar
you know how all motor sounds different than a boosted motor?mine kinda sounds like that.did your Bov stop blowing off?
Old May 10, 2009 | 11:08 AM
bossm's Avatar
northrm did your bov stop blowing off??????
Old May 10, 2009 | 02:22 PM
AJxr's Avatar
maybe you have a serious boost leak?? even though you are making full boost it could still be leaking
Old May 10, 2009 | 02:32 PM
northemt88's Avatar
yeah,the same day it stopped working it was working good
Old May 10, 2009 | 02:51 PM
Pleiadi79's Avatar
sparks rotor? all ok ? Did u check fuel pressure? timing is ok? Too rich?
Old May 10, 2009 | 06:34 PM
INeedMoreGOFAST's Avatar
Check your timing.
My GSR did the same thing a few weeks ago...turned out the intake cam jumped time.
Old May 10, 2009 | 07:52 PM
northemt88's Avatar
Originally Posted by INeedMoreGOFAST
Check your timing.
ill check thanks.did your car drive ok when that hapened?
Old May 10, 2009 | 11:11 PM
no, any more than 10-15% throttle it bogged like a ****.
It was a tooth retarded on the intake cam... since you are bogging the opposite as my car was you may be advanced....who knows? Just check timing, it's free. Always check the free stuff first.
Old May 11, 2009 | 06:16 AM
northemt88's Avatar
thanks man that is true check free stuff first
Old May 11, 2009 | 09:11 AM
Turbo-LS's Avatar
wait your running an FMU for now to save for a shittty aem ems LOL. dude crome = freeware is 1000% better than fmu and gets the job done. AEM sucks period. if you want to spend some money on a good system get hondata s300 or ectune or neptune or if you really wanna drop big money get a motec
But it sounds like you could have a few problems, i would first start with boost pipes. if one is leaking you can stil read 8 psi on the gauge but not get the air flow and not make power. also could be motor letting go from to much timing with that fmu setup you've got there. probably cracked ringlands if you didnt back timing out
b18sihatch
Mar 29, 2006 05:03 AM
hoskos
Jan 21, 2006 05:57 PM
TA Performance
Feb 12, 2005 06:25 PM
n1_ek
May 11, 2004 09:47 PM
SpeedBump
Jul 23, 2001 01:35 PM
