What should i do?
Old Aug 17, 2002 | 02:47 PM
CherryRacing's Avatar
Default What should i do?
Am i looking to buy a new honda. I have cash. i want a 92-95 coupe or hatch, should i buy a allready motor swapped car? or buy one from a person with mad miles on it and do my swap the way i want it. What is cheaper? thanx
[Modified by CherryRacing, 11:47 PM 8/17/2002]
Old Aug 17, 2002 | 02:51 PM
shawnhayes's Avatar
Default Re: What should i do? (CherryRacing)
Long run cheaper is to buy someone else's project, so long as the body is in good shape. But, make sure that the body is in good shape. Many a good swap has gone bad because of a bad chassis.
Shawn
Old Aug 17, 2002 | 03:08 PM
akeldama's Avatar
Default Re: What should i do? (shawnhayes)
Ooh, Ooh, buy mine
Old Aug 17, 2002 | 03:16 PM
deepnite's Avatar
ur in a very enviable position..uve got *cash*...there s alot of hybrids out there to be had for a decent price..remember these cars are worth alot more to the owners than to u as a buyer...what do u want in a car? exactly..there s probably no car that meets all ur want list..so just find one that closest to it and finish off the project to ur liking.
Old Aug 17, 2002 | 03:25 PM
racecarpete's Avatar
Default Re: What should i do? (deepnite)
this is very true. You obviously have a general idea of what you want the car to have cause you are looking to swap or buy a swapped car. Just find one close to everything you want and finish it OR buy a really high mileage car and build the car up to your liking. In the end it will be cheaper to pick up someone elses project but you run the risk of wondering how they treated the engine because everybody swaps engines for one reason, to go faster.
Old Aug 17, 2002 | 03:35 PM
neveronlines2k's Avatar
Default Re: What should i do? (SilverCivic2k)
If you buy an already swapped motor have a leakdown and compression test done to the motor (preferrably before you buy it) And that should give you a good idea of what condition the motor is in. . Good luck
GripFactoR's Avatar
be a man.. swap it yourself.
that way you know how everything is installed
and you dont have to worry about someone elses BEATEN car...
Old Aug 17, 2002 | 04:42 PM
Archidictus's Avatar
Unceasing Measure
Default Re: What should i do? (VTECxSiR)
exactly. it's rediculously easy to put b- and even h- engines into EG's...you should do it yourself, simply for pride if nothing else.
edit: just put a b18c and a d16z in a pair of EG hatches within two weekends. the b18 started on the first crank, the main relay in the d16 EG was dead, but after we replaced that (for ******* $45...damn honda!) it turned on and ran like a charm.
engine lift $150
mounts $200
help $50 for pizza, beer/soda/whatever
knowing you just built yourself a mustang killer priceless
there ARE some things money can't buy
[Modified by Archidictus, 8:45 PM 8/17/2002]
Old Aug 17, 2002 | 05:59 PM
Pho Real's Avatar
Default Re: What should i do? (Archidictus)
but your mom aint one of them
Danny_EJ
Northeast (Sales)
25
Sep 19, 2008 04:40 AM
X-Psico
Jun 12, 2007 01:46 AM
Xenobi
Mar 29, 2006 04:01 PM
Spade
Aug 26, 2002 11:23 AM
127.0.0.1
15
Jul 2, 2002 12:39 PM
