need help with passing emissions
went yesterday and failed
here are my results...
HC(PPM)-180=Pass I got 222
CO-1.3=Pass I got 3.73
Also failed the idle limit for HC(PPM)
Passing is 220 and I got 365
I cleaned my injectors, used seafoam in the gas tank, oil, and through a vacum line to go straight into the mainfold and still failed....
Havne't gone back to emissions yet gotta run a full tank on the G2P...
So i went and got some Zmax for the oil and the G2P(Guarantee To Pass) gas treatment from shucks....
Got an eg with a bone stock 00 GSR swap running on a p28 with a jdm b16 base map...
anyone deal with the same **** help a brother out, tabs expire in like 2wks
thanks....
thanks....
i have one but its an aftermarket gutless one... i was thinking of that also...
basically straight pipe all the way down to the axel back where i have a stock 99/00 civic si axel back on it...
Got a old skool skunk2 manifold on it and my intake on it is a stock gsr inatke with a k/n filter so i dont think the intake part is making any difference... thanks though...
run a stock gs-r ecu. i had that same swap...bone stock with everything working..co2 and knock sensor...no lights and i passed without a cat and with 2 1/2inch piping
DAM IT WAS HARD ENOUGH FINDING MY P28, LOLZ... NOW I GOTTA FIND A GSR, ANYONE HAVE ONE FOR ME TO BORROW FOR LIKE 15MIN, HAHAHA.... i HAVE 2 OBD2 GSR ECU'S BUT THEIR USELESS TO ME... DAM IT...
are you trying to buy a free pass through emissions? lol.. should this be moved to tech forum? idk just curious. anyway have u thought about registering out in the boonies? heard you dont need emissions in some areas
fill ur tank 1/4 full of gas and put in a cup or 2 of as close to 100% rubbing alcohol as you can get. after u pass fill ur tank the rest of the way to dilude the alcohol. it wont hurt your car.
also, i have gotten two cars to pass with mild built LSVTECs in them (PR3 pistons, one with CTR one with S2S2 cams). i gave them a stock P05 (92-95 CX) ECU to run. obviously you dont wanna be ripping around on the car with the ECU in (or the rubbing alcohol), i would throw the ECU in when your just around the corner. neither car had a cat...
yeah i herd rubbing alcohol would work but haven't tried it... I have a vx ecu would that work, lolz...
at first when i got my p28 i chipped it with a gsr base map but for sum reason the motor didnt run right that's why i used the jdm b16 base map and it runs like a champ...
thanks for the ideas, appreciate the help...
thanks....
thanks....
went agian today and also freakin failed...
got a stock virgin p28, the G2P, same straight pipe, retarded the dizzy and got worse scores...
so tomorrow imma throw on a stock civic si exhaust, exhaust headers, cat the whole works and imma try the alcohol thing also and if i can't pass then i guess i'm screwed until i find another way to pass my car...
tryinig to pass it legit so i know what to do every year and passing it on the first/second try and no more second guessing ****...
Moto DC2
Oct 2, 2007 04:02 PM
blackrex
23
Jul 12, 2005 11:29 AM
