95 d16z6 in a 97 civic EX ?
Old May 8, 2009 | 08:26 AM
bigturbo's Avatar
Default 95 d16z6 in a 97 civic EX ?
Hello, I have the oportunity to pick up a 95 d16z6 to put in my 97 civic. Right now the motor in my civic has a thrown rod but all the sensors...etc are good. Im not sure if the head has bent valves quite yet. My question is will I be able to swap the d16z6 into my car and run it with my odb2 harness and computer? Or will I have to use the head from my d16y8?
Old May 8, 2009 | 08:42 AM
SpeedoKing's Avatar
Default Re: 95 d16z6 in a 97 civic EX ?
you will have to buy a conversion harness i dont think they are that expensive you can find them in the marketplace or at most part sites. My quesiton is why are you swapping a z6 for a y8 they make the same numbers, and are essentially the same motor?
Old May 8, 2009 | 08:44 AM
92egvx's Avatar
i believe u should be able to run the z6 but i think u need to swap the intake manifold though....not so sure but pretty sure...
Old May 8, 2009 | 08:58 AM
bigturbo's Avatar
The Y8 is blown, And I found a z6 for 300 bucks so thats why I was going to move to the z6. the only y8s I have found are a lot more expensive
Old May 8, 2009 | 09:03 AM
xwhitchx's Avatar
just get a d16b for $650 with 30-50k mils on it and call it a day
Old May 8, 2009 | 09:06 AM
fc3srx729's Avatar
i agree with xwhitchx, just get a JDM D15...
Old May 8, 2009 | 10:04 AM
SpeedoKing's Avatar
yeah go with the D15 you wont have to worry about fixing that rod, not to mention any other problems with the engine.
Old May 8, 2009 | 12:09 PM
20-EM2-05's Avatar
^ x2
travisjmercer
Sep 22, 2013 04:12 AM
DOUBLExDEUCEx22
May 8, 2010 12:24 AM
