codes 4-7-15-21-41
Old May 7, 2009 | 09:32 PM
junior_tm's Avatar
Default codes 4-7-15-21-41
4 CKP - crank position sensor
7 TPS - throttle position sensor
15 Ignition output signal
21 VTEC spool solenoid valve
41 Primary oxygen sensor heater
code 7 i'm replacing that tomorrow
code 21 the wire was not plugged
my car still drives but only revs till 3.5k and drinks gas like a mudaf*
which wires are the ckp please tell me the color too n how to fix it
whats in the world is o2 sendor HEATER???
ignition output how do i change that
input please
95 civic ej1 with b16a3 gsr tranny stock everything else
Old May 7, 2009 | 09:37 PM
civic_driver's Avatar
Default Re: codes 4-7-15-21-41
Probably a wiring issue. O2 sensor heater is the heater element on the o2 sensor (it heats up the o2 sensor so that it functions properly).
Old May 7, 2009 | 09:39 PM
junior_tm's Avatar
so i have to change the o2 sensor?
Old May 7, 2009 | 09:42 PM
Don't know. You have a lot of codes so it might be an issue with the wiring in your car and not so much the specific codes you're getting. If that's the case, you have to fix the wiring. Otherwise, you will have to replace the O2 sensor and the rest of the stuff that's causing error codes.
Old May 7, 2009 | 09:46 PM
junior_tm's Avatar
i did a wire tuck in my car so i guess i have to redo it
damn i hatedafter i started oh well back to it i guess
phbrush
27
Dec 17, 2014 07:25 AM
gitarman2
May 10, 2013 06:52 PM
JoshJosephKeith
May 4, 2009 04:38 PM
PH3593A
Oct 13, 2004 10:14 AM
