Is this normal for my cv axle? cant push it in anymore!
Old May 7, 2009 | 07:11 PM
accord99power's Avatar
Default Is this normal for my cv axle? cant push it in anymore!
99 honda accord f23a1 manual tranny. On the passenger side the axle will only push in this far(as shown in pictures) wanna say around 1/2" from differential. Axle did pop out from a recent clutch job i did. hoping nothing wrong happened in the tranny the splines felt fine in the differential but im no expert.
Old May 7, 2009 | 07:45 PM
bdmlilburn's Avatar
Default Re: Is this normal for my cv axle? cant push it in anymore!
turn the drives axles while pushing on them until it engages the spline and can turn the opposite driveaxle. apply pressure on the inner cv joint by pushing the axle in towards the tranny until it won't mope then use a hammer to strike the hub side of the axle and watch it slowly slide into the tranny. of course you made sure there were snap rings on the end of the axles before you put them in the tranny
Old May 8, 2009 | 05:39 AM
i couldnt push any further and i couldnt pull it out, wierd, but i will do what you said, sound slike this has way to much seperation.
Old May 8, 2009 | 05:43 AM
bdmlilburn's Avatar
should work. i had the half inch gap keep my car from runnin for 2 days before i decided just to force em. can can use someone really big to physically push them in or just put pressure on the axle and hammer
Old May 8, 2009 | 07:34 PM
nysdriver's Avatar
I noticed the same thing when I was replacing my axles. The driver side one comes in and out relatively easy (once you get the keeper clip out of its groove), but the passenger side was a pain in the neck. It was hard to get out, and it was tough to slide the new one back in. I did exactly what bdmlilburn says -- slide it in as far as it goes, and then gently tap it in place; it *will* go all the way in. Also, it helps to cover both the splined and the polished splineless part with clean engine oil before puttig the axle in.
Old May 9, 2009 | 05:14 AM
good info thanks man, will be doing tonight or tommorrow.
Old May 9, 2009 | 06:49 AM
bdmlilburn's Avatar
i used multi purpose grease on both hub and tranny spline ends
Old May 12, 2009 | 05:05 PM
thanks for the info, bought a new axle, got the axle all the way in now.
Old May 12, 2009 | 05:14 PM
nus_dogg's Avatar
What I would do is use a hammer and hammer the Hub end while holding the axel str8 as much as possible. Mine won't go in if I push by hand, It will only go in if I use a mallet or hammer to make it go in.
redman223
Sep 7, 2011 12:15 PM
bmxkills
Jan 30, 2011 08:53 PM
Momentum
Sep 2, 2010 10:06 AM
tallblondkid
Mar 1, 2009 11:02 PM
kanzdj1
Sep 19, 2003 02:45 PM
