I think im almost done. Please help.
Ok i have a 96 accord f22 engine in my 92 prelude si. i have the accord computer in the car connected through a obd1 to obd2 jumper harness. what is left to do for the car to operate?
i was told i need either one..
obd1 accord wire harness
obd1 h23 wire harness
or obd2 accord wire harness with fuse box?
does anyone kno what i have to do? please help me.
if ur running a 96 up ANYTHING motor, youll need the obd2. i dont think the obd1 harnesses will werk becuz of diff regulations and if you have vtec in your f22 that changes alot also. hope this helps.
umm i had obd1 to obd2 jumper harness. its for the computer to hook up to the dash.
im talking about wich harness should i use for the engine to the fuse box.
Ok how do i adapt a h23 non vtec harness to a 96 accord f22? some of the wires dont plug up. And right now im lost on what to do.
u have to figure out which wires on the harness go to which sensors on the new engine. if they dont reach, u have to extend them. if they are to long, shorten them. if the connectors are different u will need to change the connectors out with the correct ones.
