Need help!!** tps issues ! oposit reading......
Old May 6, 2009 | 11:46 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Need help!!** tps issues ! oposit reading......
So im trying to recalibrate my tps cause i believe its gone off do to starting and idling issues. it started one day after for some reason i cant remember i adjusted the throtle cable on the stock throtle body then later that night after work it shut of everytime at a stop and wont start cold unless i hold the gas and adjust the throtle nut to put trntion on the wheal to keep a steady idle at 1,100rpm! theres a check egine light but i cant read it cause of the hondata s100 and when i use the pin circut to the plug by the glove compartment the check engine light goes away! but im probing the wires and im getting wierd readdings! i read to set the volt meter to vdc at 20 and probe the yellow/green wire with the black probe and the red/black wire with the red probe my readings are the oposite of what its suposed to be at idle its around -4.50 when i adjust it a little and at WOT its around -.45 when i adjust it and if i switch probes to the same wires i get a + reading of 4.5 at idle and around .45 at wot what could be the propblem im stumped and need to get this car running correctly by tonight.
update, i noticed my fan switch wires came apart from the plug cause of a bad shrink wrap job cause i had to extend the wires for my jrsc also i noticed a crimped wire in my obd2 to obd1 harness so i striped it a little and put soder on, i put everything back and still wont start unless a adjust the throtle cable nut a little to put tention on the wheal so it starts and idles and the check engine lights still there also i have a spare b16 tb and the tps read about the same oposit of what its suposed to be at, do i have 2 bad tps sensors? or am i doing something wrong? please help guys.
Old May 7, 2009 | 12:47 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Need help!!** tps issues ! oposit reading......
need help
Old May 7, 2009 | 02:13 AM
wunfstgsr's Avatar
Loved
Community Favorite
bump!!
Old May 7, 2009 | 05:16 AM
redflaredcrx90's Avatar
http://www.clubintegra.com/board/showthread.php?t=21792 tri this it will help ya
Old May 7, 2009 | 05:43 PM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by redflaredcrx90
Thanks i saw a thread on a how to here and it gave me wrong info boo anyway thanks man that helped me out i was probing it wrong, well anyway it was off so i calibrated it then i noticed i had a pinched wire from the iavc so i shrinked wraped it and also a pinched wire on my ecu harnes adapter so i sodered it and finally a slight cut in a vacume hose that i fixed and now the car runs great thanks edflaredcrx90!
Old May 7, 2009 | 07:47 PM
your welcome
turbo-crx
Oct 1, 2011 10:24 AM
Spence
Apr 14, 2006 03:45 PM
93CX
24
Apr 15, 2005 07:14 PM
kholmes
Oct 12, 2004 06:59 PM
MeanGreenEG9
Apr 8, 2003 07:06 AM
