jdm b20b in 98 gs
Old May 6, 2009 | 06:44 PM
adammartini's Avatar
New User
Icon2 jdm b20b in 98 gs
would i be able to just drop a b20b in a 98 gs useing stock gs trans, ecu, wire harness, ect
Old May 6, 2009 | 07:45 PM
DAintegraGSR's Avatar
Default Re: jdm b20b in 98 gs
Trans will be fine, you will need an ecu im preety sure or have it worked by rywire.com, almost positive youll need mounts, and header if im not mistaken.Wire harness will need modification i belive
Old May 6, 2009 | 07:47 PM
sp00ledbseries's Avatar
FALSE
You are fine it will drop rite in
Old May 6, 2009 | 08:49 PM
vladd's Avatar
you are mistaken; the mounts and header are the same. i know the im will need to be swaped to the stock ls one, also possibly the distributor and injectors (not sure on those).
Old May 6, 2009 | 11:39 PM
V8 Eater's Avatar
what you want to do is switch the intake manifold,tb(all sensors)exhaust manifold,dizzy,cams(only if it is a 96-98 b20,check year code on the head) from over the b18b to the b20,this will allow you to run the new engine with the least modification and no need of a tune since the stock ecu for a b18b already runs abit rich making it ideal for a b20. though please note that you do have to do this which is very easy in order to use a jdm b20 http://technet.ff-squad.com/ckftrick.htm also note that it is worth it to go with the high compression b20 as it will put out more hp,get better mpg,has a better chance to have less mileage(99-01 version b20,has a box on its intake manifold)
Old May 7, 2009 | 12:07 AM
I was assuming that you were switching your IM/TB/sensors and other **** over
black0hatch
Honda CR-V & Element
Sep 10, 2016 05:48 PM
guapanese
11
Jun 20, 2014 09:53 AM
98ekls
Mar 18, 2014 07:55 PM
SpoonR617
Oct 19, 2004 01:07 PM
lakerschamp2000
Sep 26, 2004 01:20 AM
