whats this tube?
im wondering what the tube right next the the radiator is that makes a u-shape and at the top has i little blue cap with and "L" on it. some blue-green liquid is leaking and i think it was from here so i unscrewed the big nut a little ways and it started hissing as gas was released and when i tightened it back, it kept hissing for a good 20 minutes. anyone know what the tube is? what its for? and what might be leaking out?
yup, L stands for low side. as far as the leak go to local parts store, they carry a shreder valve kinda like whats in your valve stem. Replace it and recharge your system.
That is your low pressure side hose of your AC system, and to the person above what the hell is freon....Don't you mean R-134a....Get your stuff stright and stop giving people wrong information...To the OP, take it to an AC/Heater tech. they will take care of your leak, and re-charge your refrigerant...
The dealer has to do both, because you shouldn't work on AC components, because you can cause injury to yourself and the ozone....That's why I said that you need to take it to a AC/heating tech...You can call acura and find out the price on that hose. Heads up AC work is pretty expensive...That's all I can really tell you on that matter.
dgdarien
Jul 21, 2017 05:15 PM
K I T T
Jul 22, 2004 07:39 AM
