Dried Up Piston Rings?
Old May 6, 2009 | 02:35 PM
fizik's Avatar
Default Dried Up Piston Rings?
I have a motor that I picked up from my friend. He left the spark plug wires out of the motor and it sorta sat there for a while, so now the motor cranks but it won't turn over. Another friend told me that the piston rings might be dried up and dropping a couple drops of oil into it will fix that. Does that sound reasonable?
Old May 6, 2009 | 02:37 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Dried Up Piston Rings?
That is a good idea, many people do that to a motor that has been sitting for a while. You may want to use more than a few drops though.
Old May 6, 2009 | 03:10 PM
TravisCadello's Avatar
Put ATF in each piston and let it sit for a few hours then try in turn it with a socket on the pulley bolt. to turn the crank. Automatic Transmition Fluid If you didn't know.
Old May 6, 2009 | 03:13 PM
fizik's Avatar
Okay cool, I'll give that a try. How much would you recommend me putting into each piston? I don't want to put too much, or too little.
Old May 6, 2009 | 03:17 PM
just enough to surround the outer part of the piston where the rings are so it seeps down their and soaks the rings.
Old May 6, 2009 | 04:30 PM
wkpmichael's Avatar
Worked for me
Boyle.R
Jun 21, 2014 12:38 AM
94EGKUSH
Jan 3, 2009 02:34 PM
SiBuddy00
Mar 7, 2005 11:37 PM
2slo4me
Jun 12, 2003 01:12 PM
