ls rod + bearing questions..
Old May 6, 2009 | 06:52 AM
kyden's Avatar
Default ls rod + bearing questions..
i'm building my ls bottom end, and i have a few questions..
i noticed on the stock rod, theres an oil hole on the big end to lubricate the walls. on the manley rods i have, theres no oil hole. so how does the wall get lubricated?
and my second question is, are using b16 bearings better than the ls? i hear the b16 ones are a little better for high rpm. but b16 bearings don't have the hole in the center like ls ones do.. so not sure which to use?
Old May 6, 2009 | 07:42 AM
SilverEk3dr's Avatar
Default Re: ls rod + bearing questions..
There will be no difference with or without the oil hole in the rod. There is plenty of 800+hp cars running manley rods without a prob.
As far as the bearings go. I really couldnt tell you. Never really thought about it myself. Always just used the bearings that were originally intalled in the motor.
Old May 6, 2009 | 08:41 AM
champLSinteg's Avatar
B16 bearings will not fit LS rods. The tang is in a different spot. You will need to machine the rods to accept the tang on the bearings.
Old May 7, 2009 | 09:47 AM
kyden's Avatar
really? ugh. i'll just use ls bearings then i guess.
Old May 7, 2009 | 10:30 AM
redlinetuning's Avatar
inspect your bearings for any wear. Should you see any scuffs, etc, you may need to get your crank micropolished and get new bearings. Should check the clearances, whether you're reusing your old bearings or new ones.
divads
Jul 14, 2009 01:30 PM
DC_Legacy
23
Nov 2, 2007 04:14 AM
DC_Legacy
Oct 31, 2007 05:04 AM
Spence
32
Sep 29, 2005 03:32 PM
Race Egr
Sep 30, 2004 09:36 PM
